Is there any particular reason why some numbers appear to have decimal places while others do not?
It’s hard to tell without a file to inspect, but you probably have some tiny decimals. Also note that one can set how Grasshopper displays decimal numbers here:
Thank you for the help. But it doesn’t solve the issue. I am attaching the file for your reference.
Wall g code.gh (412.9 KB)
The Concatenate component is converting floating point values to strings. If you want to control the formatting of this conversion, you can use the Format or Expression component.
Wall g code_re01.gh (420.7 KB)
These formatting codes are a pretty broad topic, you can get details by googling “C# floating point formatting”
-Kevin
Thanks a lot!!
