I generated a bunch of planar closed curves and their in-plane bounding boxes. The planes are in different orientations. If I use Curve|Curve or Curve|Line to find the intersection points of the curves with their bounding boxes I get a handful of results. If I bake the curves and boxes, Rhino finds hundreds of intersections (every one possible in fact).
Why does Grasshopper miss so many intersections? Does it use different tolerance settings from Rhino? If so, is there a setting I can tweak to improve its result?
TIA
Jeremy
