Grasshopper : c# component output control
I try to control propagation of a c# component outputs.
Is there a way to tell Grasshopper to not propagate outputs even if inputs have changed ?
I messed a lot with Clear, ClearData, Phase, AfterRunScript… No luck. Even with no data, outputs trigger downstream components.
The only workaround I have is to change the value of another component B which is not attached to the main component A.
Maybe it is not feasable with a c# script. In that case, could you point me to the right direction ?
Regards.
There seems to be a (rather complex) way but I don’t think it’s doable in a C# script component. It would require to build a plugin with a custom component.
See this if it helps.
Interestingly, I just published a tutorial about this today! :slight_smile:
I think Jose Luis has nailed it event if not doable in a c# script as you mentioned.
Thanks.
Nice tutorial.
It is exactly that kind of info which is hard to find with Rhino.
A bit disappointing ExpireDownStreamObjects it is not accessible in a c# script.
Keep the good work !
Regards
