I would appreciate any input. I am using Rhino 6. I am creating the center of a piece. It is basically a hollowed out sphere with “extrusions” on the outside. I initially tried to flow on surface but that didn’t work. So now I have spent a bunch of time with SPLOP. It seemed like it was working until I tried to “join” or “boolean union” neither worked. I tried exploding my hollowed sphere and unioning the outside surface with the extrusions and that didn’t work. I am getting frustrated; Any ideas?
Hi Lisa - it may be that OrientOnSrf will help here, or Splop, just make sure that when you choose the origin point, it is a little bit inside the object so that when splopped on, it will slightly but definitely intsect the surface it is splopped onto - this will (assumaing a clean intersections) allow boolean operations to work.
To upload file or image here, drag and drop onto your message or use the upload button:
