I don’t know if this already exists in Rhino but I can’t seem to find it if it does. Some commands have quite a few follow up command within the command line to go through before executing the output (example: Rail Revolve). If you click the wrong line and it takes you to a the next part of the command I realized there doesn’t seem to be a way to return to the previous part of the command to fix your error. Instead you have to start over from scratch with the command which becomes tedious over time. I’ve been using Rhino for years and for some reason only now question why this is the way it is?
Is there a way to reverse or go back to a previous part a command once you are partially through to make changes?
Thanks
