Hi I’m a programmer and I’m new to rhino and grasshopper and 3d world.
I’ve just found this ghPython but from the description I don’t understand exactly what is this.
“GhPython is the Python interpreter component for Grasshopper”
So, it means that I can execute grasshopper into the python rhino scripting?
means: execute grasshopper on mac?
means: extend grasshopper with python?
It’s a component that allows you to execute a Python script inside Grasshopper. Extend Grasshopper in Python is more or less correct in that sense.
Currently you can also go the other direction and import Grasshopper modules into Rhino/Python scripts, so your first premise is also true. The documentation for this procedure is a bit lacking at the moment due to its newness.
Not at the moment - but technically it should not be impossible to add the option. But practically, it might just make sense to write the cluster in standard Python?
I was just saying ‘might make more sense’ because every level of indirection, typically, adds some overhead. It should not be terrible, hopefully, in this case.
