I have made an object using Grasshopper and I am trying to bake the object automatically whenever I change the dimension of the object. I am trying to use Ghpython script to do this. My question is
Would it be possible to do this using the Ghpython script? (if not, what component can perform what I am trying to do?)
Thank you for the suggestion,
The coding you wrote
’ Rhino.RhinoDoc.ActiveDoc.Objects.AddPoint(1, 1, 1)’
Where do I have to write? Gypython? or Rhino python script?
It would be really good if you can suggest a more detailed process.
You’ll need to “import Rhino” of course. Forgot to mention this. However if you have trouble in understanding simple function calls, then you might walk through a Python tutorial at first.
