Hi everyone. Lets see if someone knows what im doing wrong.
I have a python script in grasshopper to make combinations and products from itertools. The input is a tree made from 3 variables (in this case). The script works perfectly, but when i get out of the python window, and change the input sliders, the python node gives me this error [Solution exception:Tuple is not callable]. Then i go inside the script, press play, and works perfectly.
Does anyone one why ? I have to play test inside the script anytime i change the inputs.
Thank you! ![]()
