I wrote a ‘make material’ and a ‘bake material’ component, based in the work of many discussion at the forum. It creates the material very well but it creates infinite versions of the same material if I press ‘create’ and bake. Attached you will find the definition and the scripts. For example, if I do a material called ‘r1’ and assign it to a layer, it will create ‘r1(1)’ if I create the material again with my component. What I need is to reset the original material instead of creating so many.
"""Creates a new Material.
Returns a new Material, a Render Material and a GH Preview Material using the parameters set as inputs.
To bake into Rhino you need to use the 'Bake with Attributes' LocalCode component. The material will be baked into a layer.
Based on the work of Chris Hanley.
Typical usage:
Input a name string and a diffuse color and create a material.
The rest of the inputs are optional.
Connect the 'Material' output to assign the material to a geometry.
Connect the 'GHMaterial' to a 'Preview' component to visualize your material with GH objects.
Inputs:
diffuseColor: diffuse color
specularColor: specular color
emissioColor: emission color
transparency: transparency from 0 to 1
reflectionRange: reflection range from 0 to 1
glossiness: glossiness from 0 to 1
Outputs:
Material: Render material for Rhino geometry
GHMaterial: Material for GH preview """
__author__ = "palomagr"
__version__ = "2020.07.09"
#ghenv.Component.Name = "Make Material"
#ghenv.Component.NickName = "Make Material"
from ghpythonlib.componentbase import executingcomponent as component
import Grasshopper, GhPython
import System
import Rhino
import Grasshopper as gh
import scriptcontext as sc
class MyComponent(component):
def RunScript(self, Name, diffuseColor, specularColor, emissionColor, transparency,
reflectionColor, glossiness, create):
GHMaterial = None
Material = None
newMat = ''
def IsMaterial(mat_index):
"Verifies if a material exists in a given index"
if mat_index >= 0 and mat_index < sc.doc.Materials.Count:
mat = sc.doc.Materials[mat_index]
a = not mat.IsDeleted
b = mat.IsDeleted
print(b, "sdfsdfsfs")
return not mat.IsDeleted
return False
if create:
sc.doc = Rhino.RhinoDoc.ActiveDoc
num = sc.doc.RenderMaterials.Count
for i in range(num):
mat_from_table = rs.MaterialName(i)
# print(Name, 'inputname',mat_from_table, 'this is the name')
if IsMaterial(i):
print
'yes'
if Name == mat_from_table:
print('yes yes')
rs.ResetMaterial(i)
newMat = sc.doc.Materials[i]
else:
newMat = Rhino.DocObjects.Material()
Reflection = min(max(reflectionColor, 0), 1);
Smoothness = min(max(glossiness, 0), 1);
newMat.DiffuseColor = diffuseColor
newMat.SpecularColor = specularColor
newMat.AmbientColor = diffuseColor
newMat.EmissionColor = emissionColor
newMat.Transparency = transparency
newMat.ReflectionColor = specularColor
newMat.Reflectivity = Reflection
newMat.ReflectionGlossiness = Smoothness
newMat.Name = Name
material_gh = Rhino.Render.RenderMaterial.CreateBasicMaterial(newMat)
GHMaterial = gh.Kernel.Types.GH_Material(material_gh) # GH preview material
Material = material_gh # Rhino Material
# return outputs if you have them; here I try it for you:
return (Material, GHMaterial)
"""Bake Material"""
import Rhino
if B:
sc.doc.RenderMaterials.Add(M)
make material.gh (23.9 KB)
