Ghpyhton node for chatgpt in grasshopper
is there any gypthon or C# node in grasshopper to connect directly to openAI chatgpt from grasshopper ?
You can check “parametric camp” YouTube channel.or check swiftlet plug-in at food4rhino
@sadra
can you guide how to use swiftlet for it? thanks in advance
In examples file or siwftlet.zip there is a .gh file that works with chatgpt.BTW : you need an openai api
@sadra thanks very much , your suggestion was great and helpful .
many thanks again :slight_smile:
@sadra
Greetings,
I want to upload image to chatgpt from grasshopper using swiftlet via API , in addition to prompt text about the image .
I found an example for swiftlet to access chatgpt via API but only for prompt text .
any ideas
Hi
If you have familiar with python or C# scripting,I think that’s a better way to work on for achieving what you want🧐
