I am working with several Looping component examples. In Rhino 9 SR1 (9.1.26314.09001), changing the Loop Repeater value with a slider or manually will not trigger the Looping cluster to recompute.
I have to manually “Recompute Solution” in order to see the effects of changing the values of the looping cluster. An example file is attached.
