Ok everything was going good until I hit a wall on these couple curves. I’m trying to learn what the limits are on this set, I think it should work but running out of ideas.
While I’m not necessarily trying to fillet this set, it fails to union. So, maybe I should remove some components and break it down till I figure out using more simple terms… idk…
Glad you posted cause I couldn’t find my post after it created I didn’t add the file yet
So, that’s interesting, I didn’t necessarily even consider splitting these shapes at the midline, but it’s probably a very reasonably thing to do, and if it helps the maths then… I’ll try it.
But what’s your reasoning with that operation? I’m curious how to word that technique
Thank you for finding that. I swear I checked that already, and even recreated a couple curves. I’ll have to verify this in a few hrs when I get back to the office. Cheers.
So, I put more energy into checking the coincidences or the ends of the curves, but nothing worked. I even decided to over lap them, and still didn’t work.
