you coerce the input parameter to a curve, but then use that as argument to rhinoscriptsyntax methods. Those methods take the GUID of the curve instead of the actual curve
You use negative tolerance
You need to give the tolerance also to IsClosable, otherwise the document tolerance or zero tolerance is used. That will give False for curves with a wid gap (like the 5.0 you have).
In your first sample you typo cCrv as ccCrv in the else-block. This typo makes you end up with None/null, since the IsClosable test fails.
Here my version with direct curve usage:
ooCrv = rs.coercecurve(oCrv)
if not ooCrv.IsClosed and ooCrv.IsClosable(tol):
if ooCrv.MakeClosed(tol):
cCrv = ooCrv
else:
cCrv = oCrv
