I’m trying to modify GH_Panel UserText in C#. I’m able to achieve that by Python but not in C#, probably because of the wrong data type (Error CS0266).
foreach( var obj in GrasshopperDocument.Objects)
if (obj.GetType().ToString() == "Grasshopper.Kernel.Special.GH_Panel")
if (obj.NickName == "Cs")
Print("Found " + obj.ToString() + " panel");
Grasshopper.Kernel.Special.GH_Panel panel = obj;
panel.UserText = "Text inserted by C#";
panel.ExpireSolution(true);
Thanks
GH_panel_UserText.gh (9.6 KB)
TomTom
(Tom)
July 29, 2020, 8:00am
2
Grasshopper.Kernel.Special.GH_Panel panel = (Grasshopper.Kernel.Special.GH_Panel)obj
Remove the Print statement
You can also pack things in to methods an do many more things
ModifyPanels(nickName, text, type, run, reset);
// <Custom additional code>
Random ran = new Random();
const string chars = "ABCDEFGHIJKLMNOPQRSTUVWXYZabcdefghijklmnopqrstuvwxyz0123456789";
public void ModifyPanels(List<string> nickNames, string text, int type, bool run, bool reset)
string idle = "";
if(obj is Grasshopper.Kernel.Special.GH_Panel)
Grasshopper.Kernel.Special.GH_Panel panel = obj as Grasshopper.Kernel.Special.GH_Panel;
for (int i = 0; i < nickNames.Count; i++)
if(panel.NickName == nickNames[i])
if(type == 0 && reset)
panel.UserText = "";
else if(type == 0 && run)
panel.UserText = RandomString(ran.Next(5, 20));
else if(type == 1 && reset)
else if(type == 1 && run)
panel.UserText = text;
else if(type == 1 && !run && !reset)
idle = "I need something to do!";
break;
else if(type == 0 && !run && !reset)
break;
else
throw new ArgumentException("Parameter not defined!");
Print(idle);
public string RandomString(int length)
return new string(Enumerable.Repeat(chars, length)
.Select(s => s[ran.Next(s.Length)]).ToArray());
C#WriteToGHPanels.gh (10.1 KB)
jia.yeap
(Jia Yeap)
September 8, 2023, 4:34am
4
Hi All, what if i wish to read panel data?
private void RunScript(string PanelNickName, ref object UserTexts)
var texts = new List<string>();
foreach (var obj in GrasshopperDocument.Objects)
if (obj.GetType() != typeof(Grasshopper.Kernel.Special.GH_Panel)
|| obj.NickName != PanelNickName)
continue;
texts.Add(((Grasshopper.Kernel.Special.GH_Panel) obj).UserText);
UserTexts = texts;
Fun exercise!
