Using a batch file, I am opening a .stl file, but I am looking to read the path to a text panel to enable saving with an edited file name? Does anyone know a method of doing this?
Any help would be greatly appreciated,
Regards,
Kevin
Regards,
Kevin
Hi @kevs3dhub,
In your plug-in, create an event watcher that executes in reponese to either a RhinoDoc.BeginOpenDocument
or a RhinoDoc.EndOpenDocument
event. The handler will be passed a DocumentOpenEventArgs
parameter which has a FileName
property.
For example, in your plug-in object:
protected override LoadReturnCode OnLoad(ref string errorMessage)
RhinoDoc.EndOpenDocument += OnEndOpenDocument;
return LoadReturnCode.Success;
public void OnEndOpenDocument(object sender, DocumentOpenEventArgs e)
RhinoApp.WriteLine(e.FileName);
– Dale
Hi Dale,
I appreciate the help I’ll try that now.
Best regards,
Kevin
