Get sub layer's object from rhino to grasshopper in c# visual studio
Hi All,
I’m developing a plug-in using c# in the visual studio environment.
I tried to simply use the sub layer name to find my objects.
  private void RunScript(object x, object y, ref object A)
    Rhino.DocObjects.RhinoObject[] myObjs = RhinoDoc.ActiveDoc.Objects.FindByLayer("subLayerName");
    A = myObjs;
But it’s a no go, and the output is empty.
Any suggestion?
Regards,
Shaun
You probably need to use the full layer name:
Rhino.DocObjects.RhinoObject[] myObjs = RhinoDoc.ActiveDoc.Objects.FindByLayer("parentLayer::subLayerName");
Note the double-colon between parent layer and sub layer name.
Hi Menno,
Unfortunately, it also doesn’t work if I only input parent layer name.
I think it should be something like how to access active rhino document correctly.
Hi @shaunwu25,
Try doing something like this:
var layer_index = doc.Layers.FindByFullPath("ParentLayerName::SubLayerName", -1);
if (layer_index > -1)
  var objects = doc.Objects.FindByLayer(doc.Layers[layer_index]);
  // to do...
– Dale
@dale Thanks! it works!
Now I have a following question.
How can I convert a rhino mesh object to grasshopper geometry(from goo to mesh)?
Regards,
Shaun
RhinoObject is a wrapper around the actual geometry and has much more information than just the geometry. Likewise, GH_Mesh is the grasshopper wrapper. So basically you unwrap the Rhino object, and wrap the contents in a Grasshoper wrapper :wink:
RhinoObject meshObject; // assigned elsewhere
if (meshObject.Geometry is Mesh m)
  GH_Mesh gh = new GH_Mesh(m);
  A = gh;
Hi @menno,
Thanks for your clear explanation!
I attach the complete code below in case anyone need it.
var doc = RhinoDoc.ActiveDoc;
var layer_index = doc.Layers.FindByFullPath("grandParentLayer::parentLayer::subLayer", -1);
Rhino.DocObjects.RhinoObject[] objects = null;
List<GH_Mesh> ghList = new List<GH_Mesh>();
foreach (Rhino.DocObjects.RhinoObject rhObj in objects)
    if (rhObj.Geometry is Mesh m)
        ghList.Add(gh);
Regards,
Shaun
