Given an object that I know is an instance, how do I get a reference to it’s parent block defnition in Rhinocommon?
Thanks,
Jim
Thanks,
Jim
Hi @JimCarruthers,
below gets the instance definition from an instance object:
import Rhino
import scriptcontext
def DoSomething():
id = rs.GetObject("select block", rs.filter.instance, True, False)
if not id: return
obj = rs.coercerhinoobject(id, True, True)
print obj
idef = obj.InstanceDefinition
print idef
print "Name:", idef.Name, " Inserts:", idef.GetReferences(1).Count
DoSomething()
does that help ?
c.
Pretty thoroughly, yes!
