Dear experts,
I would like to know the python command to get the list of rhino layers names in a document.
Thanks in advance,
Ale
Hi 603419608,
Yes, that is what I wanted. I tried it in the Rhino Python editor and it works. However, I need it to develop a Grasshopper component and when I try it in Grasshopper I get the following error message (see image below). Do you know of an alternative way to do this that works in Grasshopper?
Thanks in acvance,
Ale
I think the solution is printed in the error message , which is, as error messages go, very informative.
Prior to running rs.LayerNames() you need to set sc.doc = RhinoDoc.ActiveDoc or sc.doc = ghdoc.
Hi menno,
Thanks for you answer. I am not sure how to do this. I typed this:
import scriptcontext as sc
import Rhino as rh
import GhPython as gp
layers = rs.LayerNames()
print (layers)
and I got the following error message:
Runtime error (UnboundNameException): name ‘RhinoDoc’ is not defined
Traceback:
line 6, in script
Ale
Probably
sc.doc = Rhino.RhinoDoc.ActiveDoc
I think I forgot to add the namespace “Rhino”.
Yes, now it works! thanks!
