Hi, I am looking for a method to duplicate edge of a trimmed surface. Sounds simple but I can’t find it…Something similar to Rhino command DupBorder.
So, a trimmed surface is a BREP. To get the naked edges of a BREP, you can run this code:
ObjRef bRef;
Result res = RhinoGet.GetOneObject("Select surface for dup-border", false, ObjectType.Brep, out bRef);
if (res != Result.Success || null == bRef)
return res;
Brep b = bRef.Brep();
if (null == b)
return Result.Failure;
Curve[] edges = b.DuplicateNakedEdgeCurves(true, false); //only outer naked edges
if (null == edges)
foreach(Curve crv in edges)
if (null == crv) continue;
doc.Objects.AddCurve(crv);
