Ludovic
(Ludovic)
April 3, 2024, 9:34am
1
Is there a way to get a new RhinoObject GUID that is not yet used by the Rhino document?
My goal is to assign a GUID to an object before it is beeing added to the document. I think it should be possible as this says:
https://developer.rhino3d.com/api/rhinocommon/rhino.docobjects.objectattributes/objectid?version=8.x
“If the value is not Guid.Empty and it is not used by another object in the model, then that value persists.”
Thanks
Ludovic
(Ludovic)
April 3, 2024, 1:28pm
2
Hum I am actually not very confident with GUID, but it seems that calling Guid.NewGuid() is sufficently safe for getting a new GUID which is not used yet by Rhino (or anything else)…
Can someone confirm or infirm this asumption?
dale
(Dale Fugier)
April 3, 2024, 3:52pm
3
Hi @Ludovic ,
Yes, you can assign your own GUID
if you want. Or, you can just obtain (and store) what is returned.
import Rhino
import scriptcontext as sc
import System
def Test():
plane = Rhino.Geometry.Plane.WorldXY
circle = Rhino.Geometry.Circle(plane, 5.0)
curve = Rhino.Geometry.ArcCurve(circle)
attributes = sc.doc.CreateDefaultAttributes()
attributes.ObjectId = System.Guid.NewGuid()
print(attributes.ObjectId.ToString())
id = sc.doc.Objects.AddCurve(curve, attributes)
if id:
print(id.ToString())
sc.doc.Views.Redraw()
if __name__ == "__main__":
Test()
– Dale
