using version
Command: ggIFCVersion
ggRhinoPlugIn, Version=2.0.10.0, Culture=neutral, PublicKeyToken=null Version 2.0.10.0
Rhino Version 7 SR25 (7.25.22326.19001, 2022-11-22) Commercial
The IFC import Key/Value parameters to objects are somewhat mismatched.
Here is an object that has after import
“Pset_BeamCommon|Reference” paramater as well as
“Pset_PlateCommon|Reference” parameter.
However, the IFC on contains the “Pset_PlateCommon|Reference” parameter for this object.
Here is the IFC for testing.
IFC import test_optimized.zip (77.0 KB)
This is the second time we have noted this issue - both Tekla export IFC models.
Is this possibly corrected in newer GG versions?
