Let me know if this isn’t what you are looking for or generates what you need.
I’ll come back to you about material curves. We can certainly support this, features like this are enabled in an agile manner.
Thanks for reporting this, seems this isn’t a feature that has been used in latest version of GSA.
I’ve just revised the component in the lastest plugin on rhino package manager, if you can please update and test the attached revised example.
Thanks so much John. Works perfectly! I really appreciate how quickly you respond. Never experienced such support for any tool i have used in the past.
Thanks for the encouraging feedback, it’s always nice to hear.
Adding material curves was reasonably easy, so I’ve done that in the latest build.
I’ve also fixed the node spring property issue you recognized.
Here is an example script, update the plugin again from package manager. 230617 spring prop with material curves.gh (14.4 KB)
Let me know if you have other requests or problems.
