Hello All,
We are modelling a shelf for a company in which certain parameters are given with a JSON. Specifically the origin point of each shelf, the width, type of surface board and the number of boards. Others are given through the normal inputs such as sliders, text input,etc. That is the case for the height and the depth of the shelf as well as the shelf type.
“shelves”:
“width”: 2146,
“shelfPosition”: [0,0],
“boardType”: 2,
“numberOfBoards”: 5,
“idx”: 0
We are having a problem with a shelf, that works perfectly in Grasshopper but with certain width and certain shelf type the surface of the boards don’t load in the viewer.
This is how they appear on the Shapediver viewer:
And this is how they are in Grasshopper:
In both cases I have the same JSON, width and depth.
This only happens in the Weitspannregal , Type 1, which shows that it is not a matter of the number of meshes per geometry display.
It also happens no matter what type of surface board we choose (boardtype). I tested this in the case that a texture is not loading, which is then not the case.
Every other possibility would also give an error in the other shelf types, which is why I don’t understand how come it happens only on one.
Any idea what could be causing the problem?
