Joseph,
that is something similar with what I was getting the first time I started, with the exception that I was using fit curve component and control points to generate points on curve based on curvature. You’re using anemone which probably gives more “accurate” result but still - in bots methods - we both have to adjust the tolerance to get even number of points on both curves. Anyway, quads won’t work if they’re not planar.
The definition in the post I find quite satisfactory. I’ve managed to control the spacing of the slats via eval_crv component and than arranging those in the lists ready for creating a polyline and than extruded. Looks quite clean. There’s also a solution with triangle vertices pulled torwadrs the “spine” of the bench.
klupice1.gh (47.9 KB)
I’d still love to see Davids’ solution with planar quad slats.
