I’m hoping that for the first viable fabric template that I can make up for (not huge amounts of) lack of tension by tightening where it ties to the bottom of the boat. As long as there aren’t pockets/cupping to hold snow or water it’ll be OK and can be later refined tension wise. The tarp worked out fine this winter… just a lot of folding and tucking the front and back.
I haven’t used Kangaroo before. This Grasshopper project and another to do nesting with OpenNest is all of my exposure.
Hi Daryl - I’ve done some automation work for a custom boat cover company. Their typical approach (as mentioned by Brad): explicitly model the desired seam lines and build out NURBS surfaces from there.
In my view a mesh-to-panel approach would be more satisfying to implement but will likely take longer for a one-off project than modelling it directly in Rhino. Ivy is another plugin to check out in addition to Kangaroo - I know it has mesh segmentation tools, though I haven’t used them.
Thanks @old_taz for the reminder about those RhinoResurf plugins. I remember seeing them before but hadn’t (perhaps still haven’t) figured enough out to know whether they’d be useful.
Hi @Tommy804. I’d be interested to hear about how you’re patterning… I know a few people that make canopies for similar sized boats that do it all in tape and paper-space.
Thanks, I’ll check out Ivy if Kangaroo doesn’t pan out for some reason. I would imagine that Kangaroo would be the way to go if it works… it seems that there are more people familiar with Kangaroo to help if I get stuck with something. I am looking for more than a one-off process.
I use LightBurn combined with a custom proxy to insert gcode to enable combined laser and pen-plotter support.
Creating patterns by using photogrammetry through Polycam on an iPhone, and then drawing in my seams on the mesh, along with any other curves to shape the cover.
Or using a proliner to get points and curves from the boat. If you can get a scan, it’s much easier to design your cover later as opposed to taking points with a proliner or other comparable device.
I agree, Kangaroo is a good first approach. When I worked with that client I prototyped out a method that used kangroo + a bit of custom scripting and got decent results. Would be curious to see where you get with it - keep us posted!
