Hi all, I have been trying to figure out how to wrap this elevation along my building with flow along surface and I’m not quite sure where I’m going wrong. Is there another way I can achive to wrap this elevation in a uniform manner?
I have also attached the file incase anyone would like to take a look. Many thanks in advace for the help!
If your elevation is made of curves, you can use CreateUVCrv command followed by ApplyCrv command. The CreateUVCrv command makes flat, rectangular surface. You place your elevation curves on this surface before running the ApplyCrv command.
