Flow along mesh?
Ok, a bit slow for surfaces… it creates a very complex surface.
But nevertheless amazing! I would be glad to have it as a new Rhino tool.
// Grasshopper Script Instance
// by By Daniel Piker 250604 v2
#region Usings
using System;
using System.Linq;
using System.Collections;
using System.Collections.Generic;
using System.Drawing;
using System.Threading.Tasks;
using Rhino;
using Rhino.Geometry;
using Grasshopper;
using Grasshopper.Kernel;
using Grasshopper.Kernel.Data;
using Grasshopper.Kernel.Types;
#endregion
public class Script_Instance : GH_ScriptInstance
    #region Notes
      Members:
        RhinoDoc RhinoDocument
        GH_Document GrasshopperDocument
        IGH_Component Component
        int Iteration
      Methods (Virtual & overridable):
        Print(string text)
        Print(string format, params object[] args)
        Reflect(object obj)
        Reflect(object obj, string method_name)
    #endregion
    private void RunScript(
		Mesh M1,
		Mesh M2,
		GeometryBase Geom,
		double thickness,
		ref object a)
        Mesh offset = M2.DuplicateMesh();
        OffsetMesh(ref offset, thickness);
        var morph = new ThickMeshMorph(M1,M2,offset);
        morph.Morph(Geom);
        a = Geom;
    void OffsetMesh(ref Mesh M, double d)
  M.Normals.ComputeNormals();
  var normals = M.Normals.ToFloatArray();
  for (int i = 0; i < M.Vertices.Count; i++)
    double dist = d;
    M.Vertices.SetVertex(i,
      M.Vertices[i].X + dist * normals[3 * i],
      M.Vertices[i].Y + dist * normals[3 * i + 1],
      M.Vertices[i].Z + dist * normals[3 * i + 2]);
public class ThickMeshMorph : SpaceMorph
  Mesh RefMesh;
  Mesh TargetInner;
  Mesh TargetOuter;
  public ThickMeshMorph(Mesh RefMesh,Mesh TargetInner,Mesh TargetOuter)
    this.RefMesh = RefMesh;
    this.TargetInner = TargetInner;
    this.TargetOuter = TargetOuter;
  public override Point3d MorphPoint(Point3d Pt)
    MeshPoint mp = RefMesh.ClosestMeshPoint(Pt,0);
    return (TargetInner.PointAt(mp) * (1 - Pt.Z) + TargetOuter.PointAt(mp) * Pt.Z);
Yes, morphing Surfaces and Breps will be slower, however, if we add the option to preserve structure (so for NURBS objects it does not add new control points), it gets faster:
MeshMap_Thick3.gh (612.7 KB)
Yeah, this is a charm!
// by By Daniel Piker 250604 v3
#region Usings
using System;
using System.Linq;
using Rhino;
using Grasshopper;
#endregion
    #region Notes
      Members:
        int Iteration
        Print(string text)
        Reflect(object obj)
    #endregion
		Mesh M1,
		Mesh M2,
		GeometryBase Geom,
		double thickness,
		bool preserve,
		ref object a)
        morph.PreserveStructure=preserve;
        morph.Morph(Geom);
        a = Geom;
    double dist = d;
  Mesh RefMesh;
  Mesh TargetInner;
  Mesh TargetOuter;
@DanielPiker , Hi again!
I was testing the above script (version 3) and notice that, if I input curves, the thickness doesn’t work anymore.
Would be nice if thickness could work for both breps and curves by the same component, to have a complete tool.
Could you please do a quick update, for the sake of consistency?
Thanks again!
The ‘thickness’ value is effectively a vertical to mesh normal scaling factor. So an input point 1 unit above the XY plane ends up at 1 * thickness units away from the mesh.
It does not extrude objects - if you want to turn curves into extrusions in the mesh normal direction, you’ll need to do a vertical extrusion before connecting to the Geom input.
Yes, that’s what i’m doing.
I was thinking, that, in the case of curves, the thickness can extrude the mapped curves based on the normals of the mesh…
The reason being that mapping the curves and extruding them might be faster to compute than extruding and mapping the geometry. Specially when there’s a lot of geometry, like this:
Flow Along Mesh could also benefit from a Rigid option, for example, in case of this hexagonal mesh, the hexagons remain planar and have the same edge lenghth but the gaps in between them change… obviously some will intersect but this is to be solved by design.
Apart from this I would really like to see Flow Along Mesh implemented in Grasshopper by default. Thanks again for the help.
Hi, sorry if I bring back an old thread but it caught my eye as it’s very close to what I need to do.
Except that I have no good results. I share a file that has a polysurface (it’s a simplified version) that I’d like to flatten.
Can someone can point me in the right direction?
Forum.3dm (3.4 MB)
@DanielPiker could you have a look at my file and give me a hint as to how I could get it to work?
Thanks!
It looks like you could use FlowAlongSurface here
That’s the first thing I tried but the results were not usable, the dimensions are not preserved.
I think the problem is the parametrization of the starting surface vs the destination surface and I thought a tight mesh would take care of that.
In case somebody reads this in the future and needs to do something similar.
I got something usable with a bit of manual tweaking of the target surface in FlowAlongSurface. Here’s the method I used:
-I drew a curve in 3d, with some straight segments, that follows the basic shape of the object I wish to flatten. I could then mesure the Curve’s length and the straight segments before and after the transform to verify that the scale and the proportions is preserved.
-With the dimensions gathered, I could then adjust the proportions of the target surface by percentage. If a vertical straight segment was 10 mm before and 9 mm after, I would scale up the target surface vertical dimension by 10%.
