Hey guys! Is there a script that would calculate the overall objects’ normals and would flatten all adjacent selected faces/polys to one selected polygon or to the overall selected normals.
There is a way to set Modo’s transformation tool (scaling) to not go into negative values so in Rhino this would work if there would be a OSnap to the gumball’s center if scaling with gum ball. Thank you.
Sorry asked this before. Thanks @Jarek
@jarek (and all others)This script is having some problems with Rhino 6
Is there an update? Also I would like to have the script working by just selecting the face with CTRL + SHIFT click and then fire FM (Flatten Meshes) as Aliases. (would give me the above warning dialog in Rhino 6)
This script: PlanarizeMeshFaces.rvb (2.3 KB)
Thanks for your help!
Hi Hannes,
All seems to work fine here in V6, I don’t see the Unknown Command error…
Does this command autocomplete on your system?
Also, I don’t see a good way to deal with face preselection right now to modify this script.
Perhaps RhinoCommon (Python) scripting could help with that, if anyone is willing to give it a shot.
–jarek
@hannesgrebin, not sure if you tried this, if your Gumball is set to “Align to Object” try this:
- Select the mesh faces while CTRL and Shift is down
- Left-click with your mouse on the blue scale handle and enter 0
This will flatten the selected mesh faces. Does that help ?
_
c.
@clement would be awesome to have a snap to zero function as checkbox in gumball menu or prevent negative scaling like in MODO
