FlatShade
does not seem to work with TestMetal
thanks- this is still under very active development, please update your rhino wip install often to get the newest updates.
FlatShade is still not working in Rhino 8.2
can you post some screen shots?
Also can you please run the reset command (factory defaults) on your 8.2 install?
(save any custom bits before you do, toolbars, aliases etc)
Hi Rudi,
I’ve added this to the bug list at https://mcneel.myjetbrains.com/youtrack/issue/RH-78673/Flat-shade-not-working-with-metal
