To obtain a single NURBS curve from a multi-curve, I often rebuild with a high number of control points (here : 1000) and then use FitCrv.
In this particular instance, FitCrv goes totally crazy.
Yes, but in the initial post, the super crazy result was based on a curve with 1000.
As you throttle the CP count, there are various values that produce odd results, but the one with 1000 was completely bonkers, as you can see in my original post.
Actually, this brings back an old request I had for a tool that would do the reverse action to “Convert” which transforms a Nurbs into a polyline.
As inputs, I think it would be great to have the Tolerance as usual, plus a threshold angle where the initial polyline would be split, resulting in multiple Nurbs curves.
But above all, it would need to be ROBUST.
