First Frame
Hello Grasshopper folks,
I am currently working through a YouTube tutorial and ran into an issue. When I use Evaluate Length on a list of line-like curves and then use the Parameter output to generate perpendicular frames on the curves, the first frame’s X-axis is not parallel to the following frames.
If someone could give me a hint as to why that is the case, I’d appreciate it. Thanks!
Stäbe mit Verbinder.gh (18.5 KB)
I think this can happen. To make sure the planes are oriented the way you want them, I’d suggest using the align plane component with a single vector or vectors per plane.
Ok, good to know it’s not my fault an it “just happens like that”. I’ll do the align plane thing. Thank you for your fast answer Martin. Have a nice evening!
