Find two numbers that multiplied give a specific result
Hi I am really new on Grasshopper, and I would like to ask a question that is very useful for what I am doing, I am kind of on an emergency.
I need to find all the possibilities or a couple for two numbers that multiplied give more or less (with tolerance) an specific result based on the following formula.
phi * (variable x)ˆ2 * (variable y) = (specific value defined that comes from a Grasshopper’s panel)**
** the result can be similar to the proposed number, it will be better if it is always bigger, than it
Variable X and Y should como from a list with a specific range.
Up to today I just have this.
And new to algebra as well?
algebra_2021May17a
This curve is the solution for {-10 < a < 10}, {-10 < b < 10} and c = 137.
piaabequalsc.gh (244.4 KB)
Thank you!!!
