Find the local exteremes of a periodic boundary
Hello Everyone,
I’m looking for a way to find the local extremes of a periodic boundary. When I choose to work with periodic boundary the extremes can be found in several directions (I used RhinoCurveExtremeParameters method). Does anyone have any idea how to find local extremes of a periodic curve without optimization solvers?
P.S I’m not sure if those points are called local extremes.
Best,
Mahan
I guess you’re looking for MaxCurvaturePoints:
private void RunScript(Curve curve, ref object A)
  A = curve.MaxCurvaturePoints();
MaxCurvature.gh (3.3 KB)
Hi Mahdiyar. Is that a custom made function? Because it doesn’t exist in my library.
Best,
Mahan
It’s only available in Rhino 7 WIP.
So then it’s the question how we can have it in Rhino 6? Maybe there is a way if we can understand the mathematical solution.
MaxCurvature(Rhino 6).gh (4.9 KB)
source: https://github.com/mcneel/rhino-developer-samples/blob/6/rhinocommon/cs/SampleCsCommands/SampleCsExtractMinMaxRadiusPoints.cs
extreme_curvature_2020May19a.gh (9.5 KB)
from Curve.MaxCurvaturePoints Method:
The maximum curvature points identify where the curvature starts to decrease in both directions from the points.
Thanks Joseph. it works well.
Best,
Mahan
