It works fine with Davids code. You are only using part of it. The full code is:
protected bool CurveSegments(List<Curve> L, Curve crv, bool recursive)
if (crv == null) { return false; }
PolyCurve polycurve = crv as PolyCurve;
if (polycurve != null)
if (recursive) { polycurve.RemoveNesting(); }
Curve segments = polycurve.Explode();
if (segments == null) { return false; }
if (segments.Length == 0) { return false; }
if (recursive)
foreach (Curve S in segments)
CurveSegments(L, S, recursive);
else
L.Add(S.DuplicateShallow() as Curve);
return true;
PolylineCurve polyline = crv as PolylineCurve;
if (polyline != null)
if (recursive)
for (int i = 0; i < (polyline.PointCount - 1); i++)
L.Add(new LineCurve(polyline.Point(i), polyline.Point(i + 1)));
else
L.Add(polyline.DuplicateCurve());
return true;
Polyline p;
if (crv.TryGetPolyline(out p))
if (recursive)
for (int i = 0; i < (p.Count - 1); i++)
L.Add(new LineCurve(p[i], p[i + 1]));
else
L.Add(new PolylineCurve(p));
return true;
//Maybe it’s a LineCurve?
LineCurve line = crv as LineCurve;
if (line != null)
L.Add(line.DuplicateCurve());
return true;
//It might still be an ArcCurve…
ArcCurve arc = crv as ArcCurve;
if (arc != null)
L.Add(arc.DuplicateCurve());
return true;
//Nothing else worked, lets assume it’s a nurbs curve and go from there…
NurbsCurve nurbs = crv.ToNurbsCurve();
if (nurbs == null) { return false; }
double t0 = nurbs.Domain.Min;
double t1 = nurbs.Domain.Max;
double t;
int LN = L.Count;
do
if (!nurbs.GetNextDiscontinuity(Continuity.C1_locus_continuous, t0, t1, out t)) { break; }
Interval trim = new Interval(t0, t);
if (trim.Length < 1e-10)
t0 = t;
continue;
Curve M = nurbs.DuplicateCurve();
M = M.Trim(trim);
if (M.IsValid) { L.Add(M); }
t0 = t;
} while (true);
if (L.Count == LN) { L.Add(nurbs); }
return true;
