Fill-in item - if data Path is blanc
Question: There is a data tree with several branches.
I would like to ‘insert’ data into the branches which are ‘blank’
Any suggestion?
2023-04-28 Fill-in items - only in blanc - Paths.gh (4.9 KB)
Many thanks
2023-04-28 Fill-in items - only in blanc - Paths_re.gh (12.7 KB)
Hi Kim,
Thanks!
This works indeed.
However my gut feeling would say that there is a more straight forward manner?
like ‘insert’ item at 0, hereafter select only the ‘Last’ item.
unfortunately the ‘insert’ component does not word when a Path is fully blanc.
Anny suggestion to keep this action quit small/direct? :slight_smile:
I’ve got a three boxes solution with Weave.
Weave.gh (10.3 KB)
use this trick with Combine to add null and then Replace null.
There is a simpler solution for this:
Insert item in empty branch.gh (24.3 KB)
