I’ve noticed that some commands make changes adding perhaps questionable splits into surfaces/solids.
Anything that could be done to minimize the splitting/segmentation of surfaces makes any modeling easier downstream in the workflow.
Thank, you, Brenda
Hi Brenda- as always, an example indicating what command you’re using and what it is that you don’t like or would prefer will make it a lot easier to understand what it is you’re suggesting.
I will watch for them, though I’ve seen more breaks than I wanted in pipes and fillets.
