Hello all,
could you please help me?
I’m trying to create a ramp that consists of different tiles. Part of the assignment is to integrate python code. Lately I have succeeded to create a 3D surface of the ramp from a list of curves.
The issue is that your curves are not planar, in which case Rhino.Geometry.Extrusion.Create fails. You can use Rhino.Geometry.Extrusion.CreateExtusion with a curve and direcitonal vector instead, however don’t you want the top faces to be planar?
It’s unnecessary to produce 3 threads for the same project or problem. You could have just continued one of the other two!
Thank you for answering! The goal is to make a ramp for a wheelchair
anyway, it’s still not working tho I don’t know if the problem is in the basic code or the extrusion action I choose because everything is still so new…
import Rhino.Geometry as rg
out = []
a = []
for crv in crvs:
print(crv)
templist = []
templist.append(crv)
patch = rg.Brep.CreatePatch(templist,None,0.1)
print(patch)
a.append(patch)
vector = rg.Vector3d(0, 0, 400)
Extr = rg.Extrusion.CreateExtrusion(crv, vector)
out. append(Extr)
There may be some confusion about extruding a curve and creating an extrusion object. If the curves are non-planar, creating an “extrusion object” may not work. Instead you probably want to “extrude” the curves. Closing non-planar ends may of an extruded polysurface may present its own problems.
