you can iterate over the brep.Faces, then for each face, iterate over AdjacentEdges. For each edge, you can query the edge Tolerance, or alternatively the edge curve’s length and when it is larger than your preferred value, apply RebuildEdges to the face using your preferred tolerance. Then replace the brep with the one you changed.
Hi @clement
Thank you for the support.
When I iterate over the edges the edge tolerances are all below the desired 1mm.
I.e. via the tolerance I can’t identify them.
As I understand it this spike is shorter than the defined tolerance.
If I just blindly do a RebuildEdges() then the problem is fixed, although I don’t understand exactly what the difference before and after the RebuildEdges should be:
A TL_NurbsCurve is converted to an ON_LineCurve.
Edge vertices get more decimal places.
Some edge tolerances get bigger, others get smaller
Hi @thomas.k, your absolute model tolerance is set to 0.01 meters. Brep edge tolerance should be at least equal of better smaller than that for edges to stay valid. You cannot have (or enter) a larger edge tolerance than your absolute model tolerance. If you iterate over the brep in question and analyze edge lengths and tolerances you get:
Edge 4 length is below the absolute model tolerance. The edge 4 tolerance is not bad. Maybe you can use the edge length to detect something is probably too short and flag the object for manual investigation ?
Blindly doing this for any object would lead into further problems. What i find interesting with your geometry is that even after using _RebuildEdges using an edge tolerance of 0.0001 manually, the brep still has 5 edges instead of 4. The litle edge still exists if you analyze like this:
import Rhino
import scriptcontext
def DoSomething():
brep_id = rs.GetObject("Brep", 16, True, False)
if not brep_id: return
brep = rs.coercebrep(brep_id, True)
for f, face in enumerate(brep.Faces):
for e in face.AdjacentEdges():
t = brep.Edges[e].Tolerance
l = brep.Edges[e].EdgeCurve.GetLength()
print "Face: {} Edge: {} Length: {} Tolerance: {}".format(f, e, l, t)
DoSomething()
If you detach the trim and trim again, only 4 edges are left.
An alternative way to detect this problem without any lengths or tolerances is to iterate over the brep loops. If you get. loop.To3dCurve() for your brep face, you’ll find enough self intersections to flag it.
Hi @clement
Thanks for the detailed analysis.
It doesn’t seem to be so easy to get rid of this short edge, it keeps popping up
I think the idea with the curve self intersections is an interesting option which I will have a closer look at.
Finally, I need to find a way to remove this very short edge.
Can you maybe briefly explain why a blind RebuildEdges() to repair the input geometries is not a good idea?
Or is there another way to remove such sub tolerance curves… a kind of “Clean Brep”?
Beause it could cause that 2 faces adjacent to an edge get out of tolerance to be joined after rebuilding. BrepFace.RebuildEdges has an argument to rebuildSharedEdges, it it is set to True, you’re actually rebuilding the edges of both adjacent faces.
Before writing this i’ve checked these methods but none made a change to the brep:
Tried the last one after using _RebuildEdges, but the self intersecting loop was still there. So i guess testing for self intersections is one way to analyze it.
Did you notice the trim tolerances as well ? All trims have a tolerance of zero, only the one with a Trim.TrimCurve length below your model absolute tolerance has a trim tolerance of U=8.1452509537172091e-06 and V=1.785568254364378e-08.
Same here. But thanks for the reminder on this new method. If this still has to be done automated in R6, you could detect the edge length, then select the object and script the commands.
