I’m wondering is there a way in which i can extrude a curve along a curve and have the extrusion change dimensions at different points? For example, extrude a rectangle along a curve and set different widths and/or lengths of the rectangle at different points along the curve.
What I’m looking for would be similar to the ‘‘pipe’’ command, the way you can vary the radius of the pipe wherever you want. I know this is much more simple concept with a cylinder, but maybe there is another way of doing it with different shapes?
Thank you in advance for any help and suggestions you can offer
Tadhg
