Hey, I’m getting a little hung up. I am trying to extract the point data from various objects in a layer (all simple rectangles). so I am trying to choose the layer by name(there will be multiple with the same naming format…i.e Ballast_1), identify the objects in the layer, and extract all the point coordinates. it would be cool if it could just cycle through the layers based on the naming format. anything can help.
thanks, Chris
import scriptcontext as sc
import math
##Start Evaluation
def main():
response=rs.MessageBox( "Evaluate Classroom?", 4)
if response !=7:
#Select a layer
layer = rs.GetLayer("Please select a layer")
#If a layer is chosen:
if layer:
#Gets objID
obj = rs.ObjectsByLayer(layer)
#Selects objects
rs.SelectObjects(obj)
ObjId=rs.SelectedObjects(include_lights=False, include_grips=False)
for obj in ObjId:
cent=rs.SurfaceAreaCentroid(obj)
print cent[0]
rs.AddPoint(cent[0])
else:
rs.MessageBox("Evaluation Aborted")
main()
so far i have this. the center point is more useful to me. my selection is still manual though which is holding me back a bit
@Christopher_Gornall,
see if below is helpful, it adds the area centroids (points) to all surfaces on layers which name contains the word “Ballast”:
import Rhino
def DoSomething():
# define something as layer name to search for
search_string = "Ballast"
# iterate over all layers
for layer in scriptcontext.doc.Layers:
# check if search string appears in layer name
if search_string.lower() in layer.Name.lower():
# iterate all objects on that layer
for rh_obj in scriptcontext.doc.Objects.FindByLayer(layer):
# only process surfaces
if rs.IsSurface(rh_obj.Id):
# get the area centroid
rc = rs.SurfaceAreaCentroid(rh_obj.Id)
if rc:
# add a point on this layer
attr = Rhino.DocObjects.ObjectAttributes()
attr.LayerIndex = layer.LayerIndex
scriptcontext.doc.Objects.AddPoint(rc[0], attr)
# refresh views
scriptcontext.doc.Views.Redraw()
DoSomething()
c.
thank you, this helped, id figured out the centroid aspect but the layer selection is super helpful. thanks
