Is it possible to extract surface from va component for e.g. wall, as well as the rhino command “extract surface”?
Thank you
VA objects are (dynamic) blocks. If you enter the block, you should be able to extract surfaces, then remove them from the block.
Thank you @Eugen,
of course It is possible to edit block of va component, but I would to select directly a face (surface) of wall at the same way as is possible with “extract surface” command from Rhino.
Do you have any other suggestions about it?
Thank you again
Hi @fn_a,
I don’t think this is possible for now. I will let you know when we have a solution for that.
Hi @fn_a I don’t remember when this was fixed, but in VisualARQ 3.10 this already works with the Rhino ExtractSrf command: (the surface to extract is not highlighted in the moment to select it but at the end of the command though)
