dear All,
I’m looking for a fast way to extract all the thumbnails of 3dm files I have in a folder. If possible I would named all the new picture with the same name of 3dm file.
I work on Rhino V5 for windows.
thank to all in advanced
greetings,
Andrea
Willem
(Willem Derks)
March 24, 2016, 11:32am
2
Hi Andrea,
The way to extract the preview is is via
http://developer.rhino3d.com/api/RhinoCommon/html/M_Rhino_RhinoDoc_ExtractPreviewImage.htm
To do this for a folder you will need to pass the filenames in the extraction method, you can then save the extracted bit map on a location yiou want.
To save the preview of the current open file(note that an unsaved file will throw errors)
import Rhino
import scriptcontext
#get path of currently open document
path = scriptcontext.doc.Path
#get preview bitmap of file
bitmap = Rhino.RhinoDoc.ExtractPreviewImage(path)
#create path for imagefile by replacing extension
image_path = path.replace('.3dm','.jpg')
bitmap.Save(image_path)
HTH
-Willem
