Hi all,
Noob to using C# and scripting within grasshopper so I am finding a simple task very difficult to implement. I am trying to create a script that exports already baked geometry by selecting all existing baked geometry in Rhino or selecting by layer. So I know I need to replace the For loop that loops through the items with a “Select All” or “Select by Layer” so to speak but cannot find the correct syntax to make it work.
I am doing this simply because there are some already decent baking components out there and I don’t want to reinvent the wheel.
private void RunScript(DataTree<GeometryBase> geometry, string FileName, string directory, bool export)
if (export){
List<Guid> guids = new List<Guid>();
for (int i = 0; i < geometry.BranchCount; i++){
for (int n = 0; n < geometry.Branches[i].Count; n++){
var geom = geometry.Branches[i][n];
var guid = Rhino.RhinoDoc.ActiveDoc.Objects.Add(geom);
guids.Add(guid);
Rhino.RhinoDoc.ActiveDoc.Objects.Select(guids);
string filepath = Path.Combine(directory, FileName);
string cmd = "_-Export " + "\"" + filepath + "\"" + " _Enter";
Rhino.RhinoApp.RunScript(cmd, false);
Rhino.RhinoDoc.ActiveDoc.Objects.Delete(guids, true);
I’ve tested this previously and it works if I directly input the baked geometry and get its guids. Any help would be much appreciated.
Thanks
