Spaceclaim does import Rhino files converting layers to parts (i.e. blocks) still keeping blocks intact.
From what I remember parts with identical name are treated as blocks
I think this is the BIG missing part in STEP export.
If this is accomplished then 3DM files can be finally imported into any Solid Modeler which would be a big feature added to Rhino!
From what I know the only Modeler around which does a nice conversion (both ways) is Spaceclaim (and Ansys is messing this in Discovery which has 3dm link broken since more than a year)
You can import already the geometry of course in Solidworks/Solidedge/Onshape… but if it is not organized in blocks everything is flattened.
I have not tested yet new block management in v8 but usually I use them for standard/repeating parts, not for file organization which is what layers are there for.
I remember discussing already about this with @pascal above.
The point was the block/layers culprit.
I hope McNeelians will hopefully accomplish this now that 8 is out and running!
STEP is an industry standard and Rhino should be capable to export correctly geometry, layers and blocks.
Thanks!
Yep, this could definitely do with some attention.
It makes life difficult to develop a product in Rhino to any serious level, which we want to do, and then share or exchange it via STEP.
