So i am trying to export from rhino via .ifc to revit but i am having this problem:
“cannot keep the elements united”
What is happening?
What is happening?
Hi Leonardo,
Looks like Revit could not join some of the elements in the IFC file. Could be some curves, walls, beams, openings in walls… This kind of message is common when the geometry has not been created in Revit. You need to select the “Desunir elementos” button to open the file.
