Explode block instances while keeping their original layers
No problem at all, @pascal! Adding another level of blocks is just a minor change to the work flow, and actually it’ll save me from placing each block on a numbered layer, so that alone will make up for it in the end :+1:
Thanks again :smile:
-Jakob
amazing! Saved so much tedious work!
This is indispensable. I have a few questions:
-is this still the best tool for this? Is there something more recent perhaps, since the last update was all the way back in 2019
-is there a way to filter hidden layers / objects with this?
This pluing is very usefull!! Thanks.
I use it to import CATIA tree in my Rhino project.
however some times it don’t be able to import the information. I am nt be able to understand if there is something wrong in CATIA or in RHINO.
As you can see it upload layer named “block NNN”
Does anyone have an image of this plug-in?
That is result of CATIA not saving the name of the assemblies correctly or it being saved the wrong step type.
For assemblies to be properly translated is better to always use step 242.
