ExPlode.rar (915.4 KB) attachment has a test 3dm file,which has a brep.
and a test plugin codes file.because I can’t find a sdk function can do explode .So I use runscript to write a explode function.
when I use Explode Comand ,the brep can be exploded to 2 brep.
but when I use My explode function the brep can’t be exploded to 2 brep
For exploding a BREP geometry in code you can use BrepFace.DuplicateFace
function and duplicate each face in the Brep. Alternatively, you can maybe use BrepObject.GetSubObjects
to split a Brep object.
Does this help?
https://github.com/mcneel/Rhino5Samples_CPP/blob/master/SampleCommands/cmdSampleExplodeBrep.cpp
menno and dale:
thanks for your help,
the link is broken
The developer samples have been consolidated under a single repo:
Does this help?
– Dale
