Expected Curve, got Array[Curve]
I am using GHPython on Rhino 6. I just offset multiple curves at various distances using the Curve.Offset in RhinoCommon. I want to find the intersection points of those curves but have the error that I need Curve and not Array[Curve].
How do I go about converting it and/or avoiding this situation all together?
even if result were a singular curve the method call would still return an array
you can do a conditional statement and triage the situation
say if you are expecting a singular offset result and the array contains more than one, that means there is a kink or knot of sorts that makes the offset broken into segments
Thanks for the heads up Will! That worked :slight_smile:
