As mention above, is there any example show how to display model in Viewport Control(in Rhino.UI.Controls) Which embed in Dialog or Form? thanks
This viewport would view the standard model elements, would you like just like to see something in this Viewport?
I want to display individual 3dm file in this viewport,It is possible?
It is @1056960357.
I’m aware of two routes ocne the 3dm is loaded in. Are you okay with that step?
For every element you can either;
1. ViewportId Filter
Add elements to the Document with a specific attribute
Curve myCurve;
ObjectAttributes attribs = new ObjectAttributes
// This means it only shows in the xaml
ViewportId = xamlViewportId
RhinoDoc.ActiveDocument.Add(myCurve, attribs);
2. DisplayPipeline
Create a custom Display Pipeline to draw your geometry, the sample below will show how.
Inside the PostDrawObject methods you can add this condition that will cause it to only show in the xaml viewport.
protected override void PostDrawObjects(DrawEventArgs e)
if (e.Viewport.Id != xamlViewportId) return;
// Call Draw methods
