Evaluate point
Is there a way when I evaluate a point to have the X, Y and Z coordinate with a reference? For example, I have modeled a building with several floors and when I evaluate a point at third floor, I want to have on Z coordinate “3rd floor +200 mm” not 7700 mm. The same on X and Y.
Thank you.
Hi Cipran - if you set a CPlane to the third floor, the Cplane coordinates of EvaluatePt should be what you want.
Thank you for your reply.
I gave an easy example, but if the building has one hundred floors this means that I must make 100 Cplanes. Also, I want the coordinate to be in form of “given name” + xxx(difference) mm. I must mark on the detailed plan a lot of coordinate points of this kind (with reference on x, y and z) and that is why I want some kind of automation if it is possible.
Hello- you’ll need a script for that.
